SLOW ISE 5
  • #32713
    sparkey
    i have a customer with a ISE 5 purchased 30/11/2006, complaining that it is taking longer and longer to complete programmes, 40c normal wash now taking three hours, also out of balance recognition getting very ‘fussy’ erratic on washes and almost always will not spin after hand washing.
    Good water pressure, pumping normally into stand pipe, normal checks show no faults
    Any sugestions?
    Are there wash time charts available for this machine?
    Regards
    Sparkey
    #236117
    gegsy
    Re: SLOW ISE 5
    sparkey wrote:Are there wash time charts available for this machine?
    Its in the User Guide/Instruction Book 😉
    Re: SLOW ISE 5
    sparkey wrote:Any sugestions?
    I would take the sump hose off the pump filter and have a look to see if a coin or something is flapping about in there? 😉
    #236119
    Goatboy
    Re: SLOW ISE 5
    Have you had a chat about expierimenting with the ‘quick wash’ button?
    #236120
    andy_art_trigg
    Re: SLOW ISE 5
    40 degree wash taking 3 hours? There must be something amiss that needs dealing with properly.
    #236121
    Re: SLOW ISE 5
    Usually a 40C wash will run about 2 hours to two hours twenty but that’s obviously dependent on the usual variables. That’s totally normal.
    If you get an OOB after that it can add a good ten minutes or so whilst it tries to sort the load out.
    The only way it can take in longer is if you change the variables, water pressure and inlet temperature being the obvious culprits if there’s no easily identifiable fault, like the heater, but any like that should throw up an error code.
    Or is it perhaps the customer being more and more impatient? 😉
    andy_art_trigg
    Re: SLOW ISE 5
    kwatt wrote:Usually a 40C wash will run about 2 hours to two hours twenty … Or is it perhaps the customer being more and more impatient? 😉
    Accusing the customer of being impatient because a 40 degree wash takes 3 hours is a bit … er .. impatient?
    3 hours is a joke. No one can spare 3 hours for a 40 degree wash in 2007.
    #236123
    Err, Andy… but it’s only two years old even if it is a Hoover Logic.
    The implication wasn’t on the time if correct, more on the customer’s perception of time.
    andy_art_trigg
    Re: SLOW ISE 5
    I just meant a 40 degree wash taking 3 hours (if it was indeed taking 3 hours) shouldn’t be normal. It sounded a bit sharp the way I wrote it, didn’t mean it to be.
    #236125
    Re: SLOW ISE 5
    I’m sure you’ll find that as 7 days has elapsed since sparkey asked the question the matter will surely have been resolved? 🙂
    Hopefully he will let us know the conclusion to end our speculation? 😉
