Slow Water Dispenser flow on Admiral GC2224GEKW fri/freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Slow Water Dispenser flow on Admiral GC2224GEKW fri/freezer
  • #86768
    Madhatter27
    The water dispenser flow has slowed.
    I have done the following to date:
    Checked water pressure at connection point. OK
    Changed water filter. Note always changed to manufacturer alerts but changed again just in case.
    Thought it was system solenoid unit at base of fridge at rear. Replaced but no change in water flow.
    Checked ice maker. Works perfectly in all respects. Thus fault is with water dispenser only.
    Have heard that water feed piping can freeze up and reduce flow. How do I check that from dispenser system backwards?
    Any other thoughts?
    #432976
    Re: Slow Water Dispenser flow on Admiral GC2224GEKW fri/free
    The only way that the feed pipework within the door can be tested is by turning the WHOLE appliance off for 48hrs with the freezer door left open and then try once the appliance is turned on again.
    If it flows correctly then the insulation in the freezer door has started to fail.
    Try turning the freezer temp to -18 instead of the standard -21 this will make it take longer to freeze the pipe and might actually might stop it freezing.
    If it doesn’t then its probably scaled up in which case not a lot you can do if you have checked for kinked pipework.
    Bryan
