Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › SM6P1F Neff Dishwasher
- This topic has 10 replies, 2 voices, and was last updated 5 years, 8 months ago by
bluejonny.
July 18, 2020 at 2:19 pm #98037
bluejonny
ParticipantHI everyone!
Noob here. I have a Neff SM6P1F (S41T69N1GB) dishwasher that has stopped sending water up to the top spray arm. After doing a bit of research, I came across this old thread https://www.ukwhitegoods.co.uk/forum…m-not-rotating with the same issue I have.
I have done basic checks on the machine, taken the pipework off inside and checked it’s not blocked and I have checked the drain pump etc. and all is fine. However, I have noticed when I peer into the heat pump in the bottom of the machine, that the outlet that supplies the spray arm has white plastic across it which I assume is the diverter. It’s obviously stuck as after a couple of cycles it hasn’t moved.
I am guessing it’s a whole new pump required (if anyone knows which one I need it would be appreciated!) but before I buy it, is their a controlling circuit board that moves this or is it independently controlled? I don’t want to replace the pump to be faced with needing a circuit board as well, as that makes it all uneconomic to repair.
Advice appreciated. 🙂
Thanks!
JonJuly 18, 2020 at 10:18 pm #470660electrofix
Moderator1 the pump and the divertor are seperate parts
the divertor is controlled by the main control boardto look up the machine i need the complete Enr number and FD number
July 21, 2020 at 7:19 pm #470661bluejonny
ParticipantHi Dave!
The information I have from what I can make out is :
E Nr: S41T69N1GB
FD 9106Hope that helps!
Cheers
Jon
July 21, 2020 at 7:30 pm #470662electrofix
Moderatorlook at the Enr number again there should be a / then 2 more digits
Fd number tells me it was built june 2011
July 21, 2020 at 7:59 pm #470663bluejonny
ParticipantAh, yes sorry /43
Cheers
Jon
July 21, 2020 at 8:12 pm #470664electrofix
Moderatordivertor valve 0440 on diag part no 644996
https://shop.ukwhitegoods.co.uk/00644996-dishwasher-alternating-valve
https://www.neff-home.com/uk/supportdetail/product/S41T69N1GB/43#/Tabs=section-spareparts/
July 22, 2020 at 8:41 am #470665bluejonny
ParticipantThanks Dave! I don’t suppose there is an online tutorial for the replacement of this? I’m fairly handy (replaced my washing machine pump successfully!) so happy to do it, just wondered if there was anything available?
Cheers
Jon
July 22, 2020 at 8:50 am #470666electrofix
Moderatornot seen any vid or anything. you could search utube
whole base of machine has to come off to do it so its not a quick job
before you jump in check the wiring to it from the board and open the board and look for damage
July 22, 2020 at 8:53 am #470667bluejonny
ParticipantWould those boards be behind the door on the top panel?
July 22, 2020 at 8:54 am #470668bluejonny
ParticipantAnd although in German this one shows me how to get the base off. https://www.youtube.com/watch?v=RmJnhnwMyno&t=158s
July 22, 2020 at 12:19 pm #470669electrofix
Moderatorcontrol board is a rear right hand side, where the mains plug goes in
