Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Small part that fell, can’t tell where it belongs
- This topic has 4 replies, 2 voices, and was last updated 5 years, 6 months ago by
SystemEngineer.
September 15, 2020 at 4:47 am #98352
SystemEngineer
ParticipantHi,
I have liebherr freezer model 9989338-09 (GN 2723)I took apart the evaporator assembly and this part fell when I removed the fan
[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://scontent.xx.fbcdn.net/v/t1.15752-0/p280x280/119487215_371843720489505_1996146291236614896_n.png?_nc_cat=101&_nc_sid=b96e70&_nc_ohc=whzi4Tk3AlsAX_IFju-&_nc_ad=z-m&_nc_cid=0&_nc_ht=scontent.xx&oh=274a925c199abffa0b13eaaa8e93e0b8&oe=5F86C649″}[/IMG2]
Can you tell me where it belongs?
I can’t find it on the schematicSeptember 15, 2020 at 6:39 am #472028Tony R
ParticipantIt belongs on the fan blade, it looks out of shape and needs to be made a bit rounder to fit tight on the end of the plastic fan blade, the centre little bar prevents you pushing the blade on too far and acts as a stop position.
September 15, 2020 at 7:24 am #472029SystemEngineer
ParticipantThank you Tony,
The fan blade is installed in the rear with motor in front of it, I can’t insert it from the front. Do I need to take apart the back panel of the freezer? I can’t pull out the evaporator assembly.September 15, 2020 at 3:36 pm #472030Tony R
ParticipantYou are going to have to push off the fan blade and remove it (not a lot of room and you will need to be on a small set of steps ) you can with a bit of fiddling around extract the blade once pushed off the spindle of the motor and fit the clip, however I do not see a problem leaving that clip off, providing the blade is a tight fit on the motor shaft and spins freely without jamming on anything.
September 15, 2020 at 3:58 pm #472031SystemEngineer
ParticipantI understand that it prevents pushing the fan on the motor axis, but it doesn’t prevent it slipping off. It fell off when I removed the fan to test it. When I put the fan back the first time, it was too close on the shaft and made some noise upon opening the door. I moved it a little back and it is silent now. I think that I’ll leave it off for now.
By the way, the freezer was too hot and I thought that something was wrong in the evaporator, but the issue was that the door magnet wasn’t in place and the fan didn’t spin. I took apart half of the freezer because of that small problem, felt like a total idiot when I realized it. -
