Thanks for the time to anyone who reads this ! Our smart drive 051 is displaying 11111000 (not diagnostic) while powered off and will power on but will not start any cycle. I have run diagnostics which returned 00101011. I did search for previous codes but had no luck so if someone could shed some light on the problem it would be most appreciated…
Kim
Out of balance switch fault. This suffers from corrosion and wiring problems. Check also the the tub bias spring is attached and pulling the drum forward slightly.
