Smart Drive 051 wont fill with water
Home Forums Public Support Forums International Forums Australasian Appliance Forum Smart Drive 051 wont fill with water
  • #31008
    hinerau
    Hi there, my smart drive won’t fill with water when I press the start button.
    If I take the lid off and hold the small button in near where the lid was released, the water will start to fill for a few seconds and then stop. It will repeat the start fill/stop fill process a few more times until it stops all together. Once it stops, the third light from the top left will flash with a beeping sound.
    In diagnostic mode, I can get the cold and hot water to run into the machine, and then empty the water back out again.
    Any ideas? :rolls:
    Cheers
    Claire
    #229365
    bigsmokepiker
    Re: Smart Drive 051 wont fill with water
    Simplest solution Would be A Faulty Out of Balance Micro switch
    Terminals Corrode & Washer thinks It is Out Of Balance
    It can Also be related to many other factors IE Main PCB or Rotor postion Sensor
    Run The Sticky & see if Can Post FAULT CODE
    #229366
    hinerau
    Hi there, Error Code 43. Just having a search now to see what it means and what to do.
    Cheers
    #229367
    bigsmokepiker
    43 out of Balance Switch fault
    #229368
    hinerau
    Hi there, fixed the switch – it had a bit of corrosion, so thats all ok. Yay!! Now it wont spin. Boo!! Any ideas what this could be?
    #229369
    hinerau
    error code 37 – pump blocked perhaps?
    #229370
    Yup, pump block error. It’s a twist fit from underneath – power off if handling it.
