Smart drive 058 won’t start
Home Forums Public Support Forums International Forums Australasian Appliance Forum Smart drive 058 won’t start
  • #20745
    ohno
    When I power up my Smart Drive 058 no leds light up. I faintly hear a repetive high pitched whistle like a switch mode power supply trying to start but maybe loaded down by something? Any ideas where to start?
    Ohno
    #188237
    bigsmokepiker
    Re: Smart drive 058 won’t start
    Are there any lights at all coming up when washer powered up ?
    If not Could be 2 Things
    1/Motor Controller
    2/Pump On this model power runs thru drain pump if Pump is faulty then
    washer will not power up
    #188238
    ohno
    Thanks for the quick reply. No lights come up at all.
    Ohno
    #188239
    bigsmokepiker
    Best case then would be pump faulty
    But more than likely M/C
    #188240
    ohno
    So the pump may be open circuit I guess?
    If it turns out to be the motor controller, what are the common faults? I suppose the FET’s would be most likely to blow.
    #188241
    ohno
    The pump measures 33 ohms with no leakage to ground so I guess that’s fairly normal.
    #188242
    bigsmokepiker
    Pump correct reading
    #188243
    ohno
    Thanks for the confirmation of the pump resistance. Is there a circuit available for the motor controller anywhere?
