First one was the “size switch” error, presumably corrected if you entered diagnostics. Second one indicates a cold water valve fault. Valve may have failed, although being a 12v device, this is fairly unlikely. It should read approx 15 ohms. Check wiring to valve and computer board, if all ok it’s the board itself.
