Smart Drive 501 Problem
  • #20873
    akdefl
    Hi all.
    If there is anyone that can help us, it is appriciated.
    The problem is.
    When you plug the machine in, wait 5 seconds, the final rinse light will come on and it will beep at you.
    Went into the diagnostics, got the following – 1101000. That was reading right to left, 1 being led on, 0 being off. Hope that is right.
    The machine was working ok before that, but the machine whilst on any cycle would sometimes just screw up, only a few leds would light up and the machine would stop. Unplug it from the wall, plug it back in and it was fine. But it would keep doing it.
    The water fill solenoids are gone, i have to get them replaced, but seeing as the machine is in our workshop and we only use it for rags, we got around that by just filling the tank from the tap!!! Seemed to work ok.
    Any help on this is greatly appriciated.
    Regards
    Andrew
    #188633
    bigsmokepiker
    Re: Smart Drive 501 Problem
    Indicates Fault code 104
    Display to motor controller communications error
    Can be display module or motor controller module fault
    Generally the motor controller
    You say inlet valves are shot (Both Hot & cold ?)
    When you fill manually do you do this for wash cycle only?
    Or both wash & rinse ?
    Motor ControllerPART#425260p $200 Aus Display Part# 426033 $130
    Cold valve P/N 426143 $45.00 Hot P/N426142$25.00
    Best to also check under washer for any signs of leaking water
    #188634
    akdefl
    Thanks for the reply.
    Yeah, both hot and cold are gone.
    We fill it manually, then during the rinse cycle, we would put more in.
    No signs of water leaking in or around the washer.
    Would this cause the problem now where the machine when you plug it in, it waits about 5 seconds, then starts beeping and the led for final rinse stays lit. If you press the power button, it goes off, but then 5 seconds later its back?
    Thanks again
    Andrew
    #188635
    bigsmokepiker
    Rinse light on is a user warning error
    When you enter diagnostics the last machine fault indicated will be
    displayed as per IST post
