smart drive 7.5 stops and starts
Home Forums Public Support Forums International Forums Australasian Appliance Forum smart drive 7.5 stops and starts
  • #14832
    lazeyjack
    HULLO
    i,M A PRENTICE ELECTRICIAN so I know hardly anything cos I’m year 1
    My mums machine trys to start, and then stops, it cycles like this no matter what mode, wash, rinse, spin, just fires and stops , fires and stops,
    Any help would really be appreciated It went trhough a complete wash cycle, til it got to spin, it beeped continually, so I unloaded it, and tried, and then discovered the above mentioned stop start thing
    Stu
    #160960
    lazeyjack
    Re: smart drive 7.5 stops and starts
    forgot to say it 7.5 excellence, GW709 AU(AUST), and on reading posts here, looks like maybe out of balance switch, now, where is dat? thanks
    #160961
    Be glad to help Stu, but, two things –
    1) Need the actual model number – GW/MW/IW and the numbers.
    2) Run the diagnostics.
    Hold Wash Temp Down, then Power On. At this point the model is important – phase 1 + 2 machines need you to push Advance once. Later machines don’t. Press Spin until Hold and Slow Spin are lit. At this point, the wash progress panel will light. The pattern will tell us the fault code. Post from right to left – 1 for “on”, 0 for “off”
    lazeyjack
    oh thanks I will try, Do you ever sleep?
    #160963
    Last post for tonight……….. 😀
    Check the Diags, I’ll check in the (our) morning.
    Cheers,
    lazeyjack
    ok mate it’s 1(fl)1011000 the red spin is the one that is flashing
    morning to you here it is 32C and humid
    #160965
    Hi Jack,
    Not a valid code I’m afraid. The spin light should not be flashing if you have entered diagnostic mode successfully – it should be on or off.
    If you would post up the model number as per my first post, I can advise you a bit more precisely.
    lazeyjack
    it is a gw709au model, thanks
    #160967
    lazeyjack
    I did actually post the model in my second mail, just so you dont think me a totel wally
    #160968
    Ok, do as the quote above, do NOT hit advance, complete sequence. Fault should come up as a combi of the 8 wash lights – read off right to left starting from “spin”.
    Just noted your second post – must have crossed in the ether, thanks.
    6c this morning……. 🙁
    lazeyjack
    ok it is 00110000
    although no matter wht I do, like turning off at socket , the sin light flashes slowly,
    maybe cos it stopped at that point, or cos water is high,
    #160970
    Ok, that one works…….
    Hot and cold valve fault. This can be a fault with the wiring harness between the motor board and the valves, it can be a fault with the inlet valves themselves (64ohm when metered out of circuit). If these check out ok, it’s probably the motor controller. At that point, it may be best to get some pro help to avoid any expensive mistakes.
    lazeyjack
    great Thanks,
    I rang FAND P Aust. and told em about you and this board, they were intrigued and impressed
    you may score a major repair contract 😛
    😛 as they are moving into UK
    One of there techs on his way tomorrow, be interesting
    bye for now
    #160972
    They’ve been to England once and it was all a bit of a balls up on the service front – shame really as the refrigeration and cooking products are first class. They haven’t set the washers loose in the UK, as most of us only have room for front loaders (they go under work surfaces, you see).
    Anyway, let us know how it pans out.
