Smart drive GW608 won’t spin
Home Forums Public Support Forums International Forums Australasian Appliance Forum Smart drive GW608 won’t spin
  • #16707
    martyjm
    our 9 year old F&P 608 is starting to show its age, it takes a long time to complete the cycle (must be old age), pausing before spinning, then spinning and not stopping (beeps). Looked into the diagnostic mode and came up with the following error code
    00000100101
    Any thoughts/help. Its a good machine and would hate to have to put it out to pasture.
    cheers
    Marty
    #171195
    Re: Smart drive GW608 won’t spin
    It’s not draining in the time allowed. Check for partial blockage in pump, kinked/crushed hose to water level switch. Pump may be overheating and stopping.
    Be advised that the pump is live if the appliance is plugged in, so be careful.
    martyjm
    Just pulled the pump out, cery corroded around the ‘coil’, some sludge in the pipe, will flush out, new pump in order?
    marty
    #171197
    If it’s got very rusty it’s been getting wet from somewhere. The pump is probably overheating as a result, so replacement is best bet. You may want to get a “hood” for it at the same time.
    martyjm
    new pump in place, all the goop cleared out of the bowl, works like new (even washes better)
    thanks for the help
    marty
    ps:for a hood, is this available as spare part, or something self made??
    #171199
    martyjm wrote:hood, is this available as spare part,
    It’s p/no 479188P, optional. If it’s all back together I wouldn’t worry about it.
