Re: Smartdrive 051 dissassembly
If You look under washer youll see a white Nut (Dead Centre)
Remove Rotor With 16mm Socket (Nut comes away with rotor)
Unscrew 4 Bolts That holds in Stator (Motor Windings)
Remove Stator away from shaft turn over & Youll see RPS
(Rotor postion sensor Little PCB)
You can only Test RPS With Special Device
Close visual check can be suffice
Check tracks for Corrosion ETC
While your There check Shaft Area for Signs of leaks
RPS Part # 420296P ($55.00aud)
