SmartDrive 058 – power on, lights on, not starting cycle
Home Forums Public Support Forums International Forums Australasian Appliance Forum SmartDrive 058 – power on, lights on, not starting cycle
  • #12586
    Zuberkarl
    Hi, I’m looking for some help with my F & P SmartDrive 058,
    When I power on the washer, all lights go on though it will not start filling.
    I removed both inlet valves and found the hot water valve needs replacing, however, this should not prevent the machine from filling whilst on cold water setting.
    In Jan 05, I replaced the reed switch and balance switch, and have pulled these out again to test with a multimeter: the balance switch works well. Not sure what to expect from the reed: resistance is approx. 4 kOhm with magnet and approx. 50 kOhm without… so seems OK. Not sure if the reed has to be installed in any particular direction. The error codes are as follows:
    0001 – 00000000
    0010 – 00000000
    0011 – 00000000
    0100 – 01000100
    0101 – 00111100
    0110 – 00000101
    0111 – 00000001
    1000 – 00010110 – 00010111 led flashing slowly/intermitently
    1001 – 01001001
    1010 – 00000101
    1011 – 11111111
    1100 – 00000000 – 00000001 led flashing rapidly
    1101 – 00100100
    1110 – 01001001
    1111 – 00010100
    Any help would be greatly appreciated.
    Cheers
    #150533
    Re: SmartDrive 058 – power on, lights on, not starting cycle
    Does it beep when you press the start/pause button?
    #150534
    Zuberkarl
    No, it does not beep…
    The standby led actually stops blinking when you press start/pause.
    P.S. Thank you for your help…
    #150535
    Zuberkarl
    I’d like to correct my last response …
    When I power on the machine, it beeps, all the leds light up, then switch off and the first led up the top (indicating first stage of cycle) is flashing… which is normal.
    The machine actually does beep on pressing the start/pause button to begin the cycle.
    Sorry…
    #150536
    Apply a bit of logic here – the lid switch is just that, a switch. So, with the leads detatched, the switch reading should be infinite if open and near as spit zero when closed. I do realise that you have replaced it once, but it seems that it is a regular failure.
    Zuberkarl
    Hi Penguin 45,
    Sure, sounds logical… I don’t know how the reeds work and thought that the trigger might be a change in resistance rather than plain ‘on/off’.
    Given your answer, I will remove the switch and join the switch circuit on the machine with some wire. The machine should now work, hence, proving that the reed is faulty.
    Many thanks.
    #150538
    Zuberkarl
    Just wanted to let you know that I removed the reed switch, completed the circuit and the machine is now working fine.
    Thank you for your help.
    #150539
    Well done, don’t forget to replace it with another new one – don’t want small children whizzing round at 1000 rpm…. 😀
