Smartdrive 058 Problems filling
Home Forums Public Support Forums International Forums Australasian Appliance Forum Smartdrive 058 Problems filling
  • #27095
    NZscratch
    Has anyone come across an issue where on filling the smartdrive 058 stops.
    It is filling on a cold or warm wash and sounds as though the water is spraying through the feed hose instead of the normal sound of flowing water, it sounds as though there is a valve half closed or something.
    The water temp light for hot and cold flash on the error.
    Any help please?
    #212574
    Re: Smartdrive 058 Problems filling
    Hi Scratch – that’s both your posts I’ve moved down here now…. This one suggests that the machine thinks it’s not getting water fast enough (water level control not responding in the time allowed). Obvious one is has your water pressure dropped?
    Anyway, use the sticky at the top of the forum to run the diagnostics – we may get some more info that way.
