I have a Smartdrive 058 – it starts filling ok and then slows to trickle – the cycle will complete but takes a 2+ hours becaus the bowl fills so slow.
I switched cold and hot around and it is the same (eg. put cold pipe into hot and did a hot wash).
When it starts filling slow, if I turn it off and on again and then start the cycle from beginning it fills at full speed – then starts to trickle in after a while.
What should i check? Or what is likely to be broken.
At the moment my temp solution is just to fill with a hose from the tub 🙂
