My SmartDrive is spraying the water (1sec on then off) instead of normal flow and after 30 seconds, it beeps and displays 10000011.
While on diagnostic mode, if I press cold or hot (temp) both valves sound good. I even bypassed the oob switch and made no difference. On diagnostic mode (with Hold & Low on) no other LEDs is on.
Shirola
The code relates to the Rotor Position Sensor not signalling correctly. This is usually caused by corroded/oxidised terminals under the drum, or chafed and damaged wiring.
The RPS itself can fail, and the computer board can also cause these problems.
