Re: smartdrive 509 error code 40 (00101000)
Bowl disengage fault
While carrying out bowl check Controller has indicated the bowl has not engaged even though pressure switch has indicated bowl is empty
Suggested actions
1 Too many suds/ie to much detergent
2 Check to see if bowl Is Lifting up & down Ok
3 Check that clutch is not & spline are not obstructed
To do this you will have to remove agitator from spline & plate under agitator
4/Check pressure tube has not kinked or come off
5 Could be a matter of a faulty motor controller(PCB)
Yes there are alot of possible causes for this fault code
