smartdrive 703
  • #23072
    bmac
    hi guys,I’m looking for some help when i select warm water temp the
    machine after a certain amount of time will stop filling and sits there beeping.
    the error code is 10001000
    thanks
    #196925
    Re: smartdrive 703
    Computer is unable to start the motor. Usual faults are dodgy wiring/connections at the motor, position sensor playing up. If the machine has been noisy, the bearings may be failing and have now seized – check for free rotation of the drum. If you’re really unlucky, the computer itself may have failed.
    Stay safe, unplug it if investigating.
