Smeg 20 or 30 watt fan motor
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg 20 or 30 watt fan motor
  • #100824
    N W
    Hi guys,
    So I have a faulty fan motor on a Smeg range cooker. Model A2A.
    I have replaced the fan motor and it needs a help to start. Slightest of nudges gets it working. After inspecting the old one, it is stamped as 30 Watts. The replacement is 20 Watts. I am assuming this is the problem.
    Can anyone shed some light on this? I can’t seem to locate a 30 watt fan.
    Am I missing something? Maybe it’s a capacitor on a control board or something knstead that may be causing the issue?
    #482318
    we would need to double check complete models as there are quite a few units with A2A in the model number. The original one with just A2A and nothing after it uses
    https://shop.ukwhitegoods.co.uk/699250073-oven-fan-motor
    you should not have to push it to start it. its either jamming or faulty
    The fan motor, presuming an oringinal just A2A changeds to this one:
    But the nut and fan blades also need to be changed along with that.
    tubafan
    It’s a shaded pole motor so doesn’t need a start capacitor. Either it’s faulty or something is binding.
