smeg 50×80 range cooker
  • #45222
    tradesite
    Changed the fan oven element on this cooker as the original had a hole in it. The wiring has been put back right but when the selector is switched to fan oven I get no supply to the element. When I select the bottom oven element and fan selection they work but I also get a supply to the fan oven element but the element does not get hot enough.
    Any suggestions?
    Regards.
    Nigel.
    #284089
    clivejameson
    Re: smeg 50×80 range cooker
    We’ve had plenty of these with failed selector switches..usually down to loose connections which can also happen elsewhere particularly the connector blocks at the back 😉
    #284090
    tradesite
    Thanks! Will take a look at that next week.
    Will let you know how I get on.
    Regards.
    Nigel.
