Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Smeg 80cm range cooker
- This topic has 6 replies, 2 voices, and was last updated 21 years, 1 month ago by
kellyboo.
February 22, 2005 at 10:01 am #8084
kellyboo
ParticipantI need to get some parts for my Smeg cooker but have no idea what the moedel is. it’s s/steel, 80cm wide and NOT the SUK81mfx. i have tried Smeg and other spares suppliers and have been sent the wrong ones in vain. if anyone has any idea of any Smeg 80cm range, please could you post them.
cheers
Apologies, now contains correct URLs
http://groups.msn.com/leeeem/shoebox.ms … PhotoID=10
http://groups.msn.com/leeeem/shoebox.ms … &PhotoID=9
http://groups.msn.com/leeeem/shoebox.ms … &PhotoID=6
February 22, 2005 at 11:23 am #126792Dave_Conway
ParticipantRe: Smeg 80cm range cooker
Those links won’t work copied and pasted from your browser like that I’m afraid, they are session created and temporary.
You should be able to find the direct url to the picture then use the side of the url and the pictures will appear here.
If you can’t, email me the pics directly as attachments and I’ll have a look.
February 22, 2005 at 12:34 pm #126793kellyboo
Apologies.
The correct URLs can now be found above.Many thanks.
February 22, 2005 at 3:57 pm #126794Dave_Conway
It looks pretty much like all Smeg ranges really as you’d expect.
Have you dropped the small storage door down to find the model number ?
It’s probably either an SUK80MFX or UK80??? type.
Sorry this is little non conclusive but all those burner rings and caps look pretty much alike.
The model may well be on the back as well if you haven’t checked there.
February 22, 2005 at 4:02 pm #126795kellyboo
Believe me I have checked every inch of it for any mark, note or hint of a model number. Nowhere to be seen. Plus as I said originally, I know it’s DEFINATELY not the SUK80mfx which seems to be the most common listing of Smeg ranges of this size.
Thanks for trying, I’m still looking avidly in the meantime.February 22, 2005 at 4:27 pm #126796Dave_Conway
kellyboo wrote: Plus as I said originally, I know it’s DEFINATELY not the SUK80mfx which seems to be the most common listing of Smeg ranges of this size.
Actually you posted SUK81MFX which also is in the same style.
February 22, 2005 at 4:28 pm #126797kellyboo
sorry! 😳
