SMEG 92MFX5 cooker
  • #75354
    rocker
    Need to fit a new cooling fan to this small range cooker, is it possible to do this without moving any gas pipes!! as on some oven gas pipes have to be removed to gain access.( not sure about this one)
    thanks John
    #394646
    rocker
    Re: SMEG 92MFX5 cooker
    has anyone a diagram please.
    #394647
    SUK 92? Dont need to disconnect gas anywhere but the hob top needs to come off which means undoing all the screws around each burner and carefully releasing each burner from the stainless top ( a gentle push on each). Supposed to change all the gaskets underneath when doing this but, so I have been told by my gas safe contractor, most engineers will not bother. Quite an easy job, I have been told.
    #394648
    rocker
    thanks eastlmark. john
