Smeg A1
  • #55075
    rocker
    customer tells me the oven shuts down, but will come back on again, when cooled, I know on the electrolux / aeg oven it is always the cooling fan stat, is it the same on these..can anyone advise.
    Thanks John
    #321859
    Oldtog
    Re: Smeg A1
    Rocker, I think you will find it is the safety stat at the rear, it cuts out when the temp is too high and cuts back again when cooled down. Its a typical bimetal situation. If memory serves me well I think it is fitted via the Neutral on the r/h/s as you face it from the rear.
    I hope this helps.
    OT
    #321860
    rocker
    Re: Smeg A1
    Thanks O T will check that out. cheers John
    #321861
    rocker
    Re: Smeg A1
    There are two stats on the rear RHS, drawing not showing which one I need, any one know please. John
    #321862
    Oldtog
    Re: Smeg A1
    One is o/c tangtegial fan, you can trace lead from stat to fan to check the other is c/c and may have one white in and one whit out, it also has a red dot on the top.
    OT
    #321863
    rocker
    Re: Smeg A1
    Thanks yet again OT. John
