smeg a1-2
  • #53544
    hilly
    the door on this model wont close all the way so i need to relace the hinges, first of all what is the way to remove these hinges and also p.nos if poss the ones i can find pics of dont look the same ?
    ta paul
    #316355
    Re: smeg a1-2
    931330815 is the part number. The customer will have 2 pins to lock the hinges in the door open position for removal. 2 allen keys will do but these are nasty hinges, especially locking the new ones for re fitting. Usually need to use sole of boot to open them up enough to slot the pins in.
    #316356
    Lawrence
    Re: smeg a1-2
    eastlmark wrote:these are nasty hinges, especially locking the new ones for re fitting. Usually need to use sole of boot to open them up enough to slot the pins in.
    You do that too …. 😆 Custs look at you like you are nuts ,but I have the scar to prove how much pressure they are under .
    Lawrence
    #316357
    hilly
    Re: smeg a1-2
    cheers for the replies, fitted them today. what a nightmare 😯
    cheers paul
