SMEG A1/2 strange fault?
  • #29481
    hilly
    sometimes when the customer selects a setting for the oven the clock goes off and nothing works appart from the cooling fan but if she hits the fascia hard the clock comes back on but it isnt always possible to set a time straight away im assuming it needs a replacement clock but its just short of £140 +vat. i realise its a long shot but has anyone else had a similar problem?
    thanks paul
    #223368
    SWERV
    Re: SMEG A1/2 strange fault?
    Could be possible burnt wiring in the loom or the terminal block 😕
    Merv
    #223369
    check the clock pcb for dry joints or, as said the wiring block at the rear of the hob.
    #223370
    hilly
    thanks for advice
    paul
    #223371
    hilly
    thanks youve saved the day again i missed the simple thing and looked at the clock but on return visit the mains block was starting to melt out thank god i asked on here first or i could have been stuck with a expensive clock!
    thanks again paul
