Re: SMEG A1 broken door hinge
The fact that you ask if it’s an easy job suggests to me that you need an engineer.
I can quite understand why the guy can’t give you any time scale on the repair as he is relying on your diagnosis to be correct. Best bet is to ask him to come and check the door hinge out and then he can order the correct parts, even though the door hinge may seem obvious there are other factors that may affect the door opening mechanism.
