Hi does anyone have a wiring diagram for this cooker, have to see one tomorrrow. Also any ideas if it has a door microswitch as the oven has failed. Appears to be power to the clock but when you select the stat and selector nothing happens. Cust informs me only the ingition for the gas hobs is working
Can give you a serial number as it is caked in dirt
Bear in mind that there’s no less than 21 variants of the A1 that I can see on a cursory look so you really need to know the suffix to get the right info. But hopefully what I’ve sent you will help.
