SMEG A2-5 Main oven not heating and Red LED not lighting
Home Forums Public Support Forums Help And Support Cooker And Oven Forum SMEG A2-5 Main oven not heating and Red LED not lighting
  • #36957
    haveago
    As title really, the main oven has stopped heating and the thermostat LED does not light up. The fan, internal bulb etc all work OK.
    Is this an element or thermostat fault?
    For this oven can you remove the element from the front?
    thanks
    bro
    #252953
    helo_75
    hmm, thats an interesting one
    usually , if the element has failed, the pilot light should be on
    a simple continuity test on the element will confirm whether its faulty or not, but the good moneys on the thermostat tbh
    but id test the element first, it isnt impossible for the element to have caused damage to the thermostat
    #252954
    haveago
    Re: SMEG A2-5 Main oven not heating and Red LED not lighting
    Got service guy out and confirmed it was burned out thermostat connection- actual connector was melted away!
    He believes it was due to incorrect connection of thermostat at factory
    All sorted now 🙂
