Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Smeg A2 Electrical Smell
- This topic has 8 replies, 4 voices, and was last updated 13 years, 3 months ago by
Jimmy Skins.
December 29, 2012 at 7:59 am #73250
Jimmy Skins
ParticipantI have recently replaced a failed main oven element in last 2 months. Everything seemed fine until just after the christmas meal where we noticed an electrical smell coming from through the vent. I have removed the back panel and isolated the fan motor then switched on – still get electrical smell. I then isolated the cooling fan – still get smell.
I then isolated the main element – smell stops.
Could it be a faulty element, I bought an original smeg part.
The oven around 2001 model.Can someone help
ThanksDecember 29, 2012 at 8:03 am #386886DrDill
ParticipantRe: Smeg A2 Electrical Smell
I would check the selector switch for burning contacts.
Sent from my iPhone
http://www.kitchenkitsw.comDecember 29, 2012 at 12:00 pm #386887Alex
Also the mains terminal block, they are known to fail if the mains cable is poorly connected.
Smell will seem apparent when element energised due to current being drawn.
Alex
December 30, 2012 at 12:24 pm #386888Jimmy Skins
Thanks, looks like the main terminal block is to fault.
Do you think this is a loose connection or do I replace with a new block?
December 30, 2012 at 6:04 pm #386889repman
It started with a bad joint and it will continue unless you replace the block
Jim
December 30, 2012 at 7:12 pm #386890Jimmy Skins
Thanks I will do that – I have cleaned and tightened the spade connector do you think I should cut back some of the wire and fit a new spade connector?
December 30, 2012 at 7:23 pm #386891repman
Yep,make it look like new or next big cook up will be the terminal block again
January 2, 2013 at 9:32 pm #386892Jimmy Skins
Thanks Jim,
Just out of curiosity why do the blocks fail?
January 4, 2013 at 8:52 am #386893repman
a poor/bad joint will create heat which in turn makes the joint worse so it gets even hotter then you end up with what you had.
Jim
