SMEG A2 Shutdown fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum SMEG A2 Shutdown fault
  • #15279
    Hulder
    My A2 burnt the dinner tonight, after operating normally it suddenly raised up to a ridiculous temperature then shut down, including the clock display. After a few minutes the clock display came back on but the main oven will not operate.
    The smaller oven seems to work fine.
    Can anyone suggest what is wrong 😕
    #162916
    gegsy
    Re: SMEG A2 Shutdown fault
    Possibly thermostat failure tripping thermal cut out when close to melt down 🙂 would reset when normal working temp reached.
    Check link below for spare or engineer.
    Is the fan running on the oven but not heating now? Often when the elements blow they can overide the oven stat and reach a higher temperature.
