SMEG A2A Oven – Inner glass Door replacement
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SMEG A2A Oven – Inner glass Door replacement
  • #22211
    MickGeorge
    Hi Folks
    Triple glass type door -Inner Door Glass had shattered.. Got replacement door glass – when fitting noticed that the original looked like it was either glued or bedded down on a brown mastic type sealent.. Phoned NEFF they say no sealent listed so not required… But that was only the spares dept..
    Do I still need to bed the glass onto a sealent?.. If so what type, make etc.
    Or is it ok without?
    Have NEFF made a mistake sealing inner glass and this is why it shattered in the first place and now a change of policy?
    Comments appreciated 🙂
    #194068
    PINKY
    Re: SMEG A2A Oven – Inner glass Door replacement
    I assume when you say neff you mean Smeg?
    On the a2 the inner is not glued in any way.Some times they seem to come away cleaner from the frame than others.We have never bothered with any mastics.
    I was always under the impression the glass had to be supported equally to avoid it shattering,Personally i cant see mastic would help..
    Pinky
    #194069
    MickGeorge
    Thanks Pinky
    Sorry it was SMEG I phoned.. (end of a long day)..
    Thanks for the info.. fitted it without mastic just asked cust not to use till I checked with you guys..
    Thanks for the help..
    #194070
    Make sure you check the oven stat is working as these fail often causing the inner glass to shatter.
