Smeg A3-5 – Problems with Main Oven Door
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg A3-5 – Problems with Main Oven Door
  • #17425
    CezarChris
    I have a Smeg A3-5 Cooker which currrently has a couple of problems with the main (large) oven.
    1) The oven seal is split at the bottom & I can’t find a part number so that I can order a replacement
    2) The main oven door doesn’t close fully at the top so instead of closing flush, it protrudes by about 5mm (by comparison the door to the small oven/grill closes completely flush)
    The door has been removed for cleaning a couple of times & as far as I can tell, we have replaced it properly but it doesn’t seem to help. Is there a spring that can be tightened or needs to be replaced?
    Thanks for any help
    Chris
    #174305
    Dave_Conway
    Re: Smeg A3-5 – Problems with Main Oven Door
    The seal is no problem, part number 754131208 at £10.27 ex VAT and carriage.
    The door hinges and/or hinge supports need replacing to solve the main oven door not closing correctly by the sound of it (they wear). Again, not a problem and pretty reasonable at 9.80 each plus the supports at £4.82 each (ex VAT).
    If you’d like any of the above, an email to spares@ukwhitegoods.co.uk please 🙂
