Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Smeg American Style Fridge Freezer Not Getting Cold
- This topic has 10 replies, 4 voices, and was last updated 21 years, 10 months ago by
ajb.
May 22, 2004 at 9:00 am #5547
ajb
ParticipantHi Everyone – I have a 4 year old Smeg as above. The fridge section no longer seems to be getting cold enough, although the freezer is okay.
Any thought from out there ?
Thanks in anticipation.
May 22, 2004 at 10:22 am #111781Dave_Conway
ParticipantRe: Smeg American Style Fridge Freezer Not Getting Cold
Can you post the model number ajb ?
I’ll check the Smeg info for you (try anyway).
May 22, 2004 at 12:05 pm #111782ajb
Dave – the only number I can find on it is smg21kr
May 22, 2004 at 1:43 pm #111783Dave_Conway
That’s not the model number I’m afraid.
Check inside the fridge and remove the salad bins, there should be the rating plate in there somewhere with loads of info on it.
May 22, 2004 at 2:54 pm #111784ajb
Thanks – how does sra25x/2 sound
May 22, 2004 at 3:36 pm #111785Dave_Conway
The only thing I can see that is easily checked is the adjustable duct at the bottom of the fridge.
There should be a lever there at the lower left corner in the fridge, it adjusts the airflow between there and the freezer, check both sides for obstruction as this unit relies on air flow to keep the fridge at the correct temperatue.
Other than that it’s a case of calling an engineer I’m afraid. If you pop your postcode here, there are quite a few Smeg agents on the site, one of them should be able to assist further.
May 22, 2004 at 5:02 pm #111786admin
KeymasterRe: Smeg American Style Fridge Freezer Not Getting Cold
hi,
there will be another damper that restricts the incoming cold air from the freezer evap into the fridge.
Is the freezer functioning normally ie ice cream is not rock hard or it is remaining frost free or bread is easily defrosted, if these are true then the damper is the probable cause.
The slider Dave refers to controls returning air usually and when the damper does not shut correctly this can ice up, along with your veg freezing.Expect a £50.00 bill for a damper and labour on top of that and use a specalist fridge engineer who has experience with American models
ted
June 16, 2004 at 8:39 am #111787ajb
Still having problems and throwing lots of food away !
Can anyone recommend an engineer in the Skipton (North Yorkshire)area ?
June 16, 2004 at 12:29 pm #111788Martin
ajb wrote:Can anyone recommend an engineer in the Skipton (North Yorkshire)area ?
If you put in your Postcode in our “Directories” section, I’m sure someone will cover your area 🙂
June 16, 2004 at 4:19 pm #111789admin
An engineer who covers that area is clive warring on 01132865757 he should be able to sort you out.
as i have previously said,this appliance is in actual fact a maytag or admiral fridge freezer badged for smeg.my previous dianosis still sands to be the defrost heaters.
bryan
June 17, 2004 at 2:07 pm #111790ajb
Thanks Bryan – will try him
ajb
