smeg( built in oven) model piano 3040
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries smeg( built in oven) model piano 3040
  • #18630
    rocker
    Dismantled, traced fault to negitive line out to fan oven element, this has a small square plastic box with 2 white & 2 blue cables linking into neg supply feeding element, (dont know what this unit is) but running hot. pretty sure this is the problem, can anyone tell me what this unit is!!
    cheers John
    #179689
    Dave_Conway
    Re: smeg( built in oven) model piano 3040
    The piano is a range and not the model rocker 🙁
    The model will begin with “F” 🙂
    #179690
    rocker
    Dave, customer tells me the model is F67-5 hope this helps
    cheers John
    PS. thanks for info on the aeg earlier. John
    #179691
    Pretty pictures in your In box……..
    Lawrence
    From memory its the tangential cooling fan delay .
    Lawrence
