Smeg CG92PX9_55
  • #100454
    grahamH2022
    Hi,First post. I got the above last April,from AO.com. The main oven has decided not to work. The light is permanently on. Before I contact AO,is there any check I can do to try and fix it?
    #480696
    which light is on ?
    grahamH2022
    It’s the main oven interior light.Digital clock/timer works. Small oven works as normal.
    #480698
    are you sure the timer is in manual mode ?
    grahamH2022
    Yes. Gone through power on/off,setting resetting. Stays the same.
    #480700
    in that case there is a list of things
    thermal cutout
    faulty clock
    faulty control sw
    door switch if this is fitted ( some do some dont )
    kaibart
    There is a problem with the door microswitch I’ve done loads in warranty smeg know there is a issue the hinge doesn’t hit the microswitch lever square and doesn’t de activate the microswitches
    #480702
    grahamH2022
    Thank you. Smeg sending an engineer this morning. Will see what he says and mention these posts if required.
    #480703
    grahamH2022
    Oven fixed. Switch at bottom left replaced. Engineer showed me the old and new switch. Only difference is the aluminium bar has been lengthened. He has them in stock and has changed a few recently… I wonder why the good old plunge bar switch has been replaced? Thank you for those who offered help and advice.
