Home › Forums › Public Support Forums › Spare Parts Help › SMEG COLD INLET FEED> DO I NEED GENUINE ONE
- This topic has 5 replies, 2 voices, and was last updated 19 years, 1 month ago by
medler.
March 5, 2007 at 11:44 pm #25599
medler
ParticipantHi,
Please help. I have just snapped my inlet feed hose for my smeg dishwasher and have checked the Smeg spares site
http://www.smeg-service.co.uk/smegshop/ … 7&sent=yesfor the part and its a whapping £52!!!! Do I really need the genuine part of will a universal one do the exact same job? There seems to be like a filter type thing on the genuine one but not sure, Please please help.
I dont want to have to hand wash again 😡
Thanks in advance
ChrisMarch 5, 2007 at 11:48 pm #206559kwatt
KeymasterRe: SMEG COLD INLET FEED> DO I NEED GENUINE ONE
Whether you need the genuine or not depends on whether or not you want the flood protection or not, or Aquastop.
If you don’t want that then there are far cheaper alternatives., like a standard fill hose, although I wouldn’t advise it.
I’m sure that we can do better on price but by how much I don’t know without looking, an email to spares@ukwhitegoods.co.uk should provide an answer tomorrow.
March 9, 2007 at 5:32 pm #206560medler
ParticipantRe: SMEG COLD INLET FEED> DO I NEED GENUINE ONE
Can you describe in detail what the flood protection actually does? The pipe snapped on the dishwasher end of my last one and that caused quite a flood untill I found the stop tap. I have fitted a standard pipe at the moment. Do you think this will be ok?
Many thanks for all your help in advance
Chris
March 10, 2007 at 10:09 am #206561medler
Just to add from my last post, I tried the dishwasher for the first time using the universal inlet pipe and water started to leak from the inside of the machine. I had to turn it off as didn’t want to cause any damage. Any ideas? This is becoming a nightmare 🙁Thanks
ChrisMarch 10, 2007 at 11:32 am #206562kwatt
Basically it shuts off the water when it detects a leak, hence the big valve type affair at the connection to the mains water.
It sounds as if you’ve got another problem though that’s caused the inlet pipe to lock out. You’d have to find out where the leak is coming from before putting it right.
March 10, 2007 at 12:07 pm #206563medler
Right- I have eventually got the side panal off and identified where the leak is coming from. Its one of the fill compartments on the side and its leaking from the join.Looks like when I pulled the machine out it must have moved from where it was originally seated. I have put it back and will do a full wash and see what happens.
If I need to remove the large plastic piece connected to the side of the machine where I think the water must enter the in side of the machine to comence washing, how do I go about this? This may have to come off if I’m to get a good seal where it fills from on the joins.
Hope that makes sence and any assistance greatly appritiated
Chris
