Smeg /COOKE AND LEWIS RANGE replacement TIMER .
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg /COOKE AND LEWIS RANGE replacement TIMER .
  • #103728
    Sparkydude
    Looking for a replacement timer module for the above oven , serial number 40213 2622 or full serial number 1 730538 40213 2622 01 13 have been offered an 816292759 but looks like original is a 816291317 . Any advice on compatability ??
    Nick
    #494357
    What’s the model number of the cooker?
    If it is Smeg I might need the SI also.
    Perfect, the current part number for the timer in that cooker is: 816292759
    They did change it though, the old number was 816291317 but you’d get the above if you ordered it on that number.
    Sparkydude
    Thanks for the help . Much appreciated. One last thing ,looking at a new fan element and side oven elements. The fan oven seems to have two versions 2 turn and 3 turn and I believe twice versions of the side oven main top element
    Any ideas how to confirm the right ones needed . Thanks again for your help
    #494360
    They changed the fan elements umpteen times, it can be 2 or 3 turn, makes no odds just some are a pain with the fixing bolts they did away with. Part number is 806890807.
    The main oven upper element is 806890661.
    Lower element is 806890652.
    There are no side elements.
    Sparkydude
    Thanks for that , my explanation was apalling lol . when I said side oven i actually meant the small oven next to the main oven lol. its that one that i ne3ed element for as they have used it so little the element has absorbed moisture and trips every time it is tried to be used lol.
    #494362
    The upper element in the smaller oven?
    That’s part number: 806890372
