Re: Smeg cooker diagram
Thanks but that was all the info I was given at the time before I went to the job.
Looked at it and it was shorting to earth as suspected. The owner had contacted SMEG and puchased a replacement simmerstat for £30 It was a blue colour and different shape from origonal. The origonals were the standard green simmerstats.
When he put the cooker back together one of the casing screws (origonal not wrong screw) went through the casing and the tip of the screw was just contacting the live on the new simmerstat. Now the house is very old and has rewirable fuses. Resistance live to earth was about 2ohms through the tip of the screw and NOT lifting the fuse. So replaced simmerstat tested ok then live tested. At which point the owner took off his shoes touched the sink then touched the cooker and was happy that the cooker was no loger “buzzing” nor was he getting any shocks.
I left him with a stern warning to get the house rewired as a matter of urgancy and that he had been extreamly lucky this time.
Having said that shurley that was a design fault from SMEG?
