Smeg cooker hood light fitting replacement
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg cooker hood light fitting replacement
  • #92933
    jojorm
    I am trying to replace two new complete light fittings in my smeg cooker hood.
    However I cant find any way to access the wiring connection points.
    The hood model is KSEIV95X.
    Any help would be appreciated. thanks
    #452639
    Re: Smeg cooker hood light fitting replacement
    done a few hoods and they are all different. sometimes when you take the lamp out the lead has a plug in it and can be swopped that way. others you have to remove the chimney and or control gear
    you could post a few pictures so at least I can see what you are talking about
    Lawrence
    you should be able to pop the lights out and then the leads with connections on should follow
    #452641
    jojorm
    hi I thought that but the leads seem stuck….certainly not moving.
