Our SMEG cooker hood made a bang when I put the lights on and it hasn’t worked since. I have changed the bulbs, changed the fuse, tried a new assembly switch and still doesn’t work. Has anybody got any ideas what may be wrong please?
Did you change the fuse in the plug or spur for the cooker hood – normally above the cupboards or I’ve seen them behind the chimney or the fuse at the spur switch above the work top – if it has one
