Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Smeg cooker SUK92MFX5 problem
- This topic has 3 replies, 3 voices, and was last updated 18 years, 11 months ago by
zozza.
April 30, 2007 at 9:37 pm #27029
zozza
ParticipantHello there
New here. i have a Smeg SUK92MFX5 range cooker and it appears as if the fan oven element or fan motor has broken.
i am looking for advice as to what I need to do about it and how much I should expect to pay to get it repaired.
i hope someone can help me
Thanks in advance
Zoë
April 30, 2007 at 11:51 pm #212338summer
ParticipantRe: Smeg cooker SUK92MFX5 problem
Hello, I got this from an older post – think its what you’re looking for (so am I!) My model was bought in Sept 2004…Yours?
Well a big thanks to this site for supplying the element for a great price and quickly.
The great news is that I received the element and it is now replaced and working fine.
The procedure was very straight forward.
At the back of the oven there are two bolts that can be unscrewed by hand/pliers or large screw driver (whatever it takes )
Then slide out the metal piece covering the back panel. It will come out very easily. You will then see the element. It is screwed in with three screws (standard sized) undo these and it will then allow the element to move slightly, don’t pull it hard, it’s attached to the wires with blade connectors. These come through a small slot in the back. Mine was connected as follows.
LEFT
|—Orange & white on the left most connector
|—Green & yellow on the middle connector
|—Solid blue on the right side of the middle
|—Blue & white on the very right hand side
RIGHTRemove the connectors carefully checking if they match what I describe, if not note them down to be safe, don’t want any surprises
Then just attach the new one and then reassemble by doing the above steps in reverse.
By the way some how the alarm has come back to full volume no idea how but just loving it!!
This was a very simple job; it was done from the front and does not require any special skills. In my view these instructions should be included with the element. Anyone can do it.
May 1, 2007 at 3:48 pm #212339zozza
thanks so much for that. Yup mine was bought around the same time!
Zoë
May 2, 2007 at 8:47 pm #212340Penguin45
Fan oven element is here:
http://www.ukwhitegoods.co.uk/modules.p … rch_resultBear in mind the bit our quoted poster didn’t say…… Power Off!
Penguin45. -
