Smeg CR330SE Drain tube blocked
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg CR330SE Drain tube blocked
  • #44959
    monkey
    Hi Guys
    I have built in smeg fridge/freeezer, the drain tube is blocked solid proberly ice,before I pull it out can you tell me if the drain is intergrated in the foam and if so have you had any problems with them freezing up.
    #283093
    spimps
    Re: Smeg CR330SE Drain tube blocked
    There is sometimes a drain heater embedded in the channel and drain hole but not sure on this one,the drain tube is just a plastic insert through the foam usually.Always open the hole through the tube whilst I’m clearing them.
    #283094
    monkey
    sorry I should have said,it is the fridge drain tube that is blocked.
    #283095
    spimps
    Have you tried poking in out with a decent cable tie or similar,not usually ice if it’s the fridge drain.
    #283096
    monkey
    It is blocked about 24 inches down the tube.
    #283097
    spimps
    Think you will have to remove cabinet from cupboard,you should then be able to get at the tube which usually goes between the condenser and the back of the cabinet,if you can’t clear you can join a new section on.
    BG
