Smeg CS19ID-6
  • #97259
    rickard
    Please can someone help with a spares manual for this cooker or some help with the fault which is the display will flicker to numbers and the no pan symbol, also in the off position if you place a pan on the hob it will start to heat up but only intermittent. Is there a board which operates the 5 plates? as I suspect this to be the fault.
    Many Thanks
    Andy
    #466694
    Lawrence
    This is going to sound really weird but what is the base of the pan like , we have had a similar fault and it was the pan being a “pepper pot” base it caused havoc with the sensor, we now carry a good quality solid base pan on the van to prove to the customers that’s what it is
    #466695
    rickard
    Thanks Lawrence, but the display is flicking on and off with numbers when no pan is on the hob at all. It just will all of a sudden switch itself on and numbers appear in the screen.
    Andy
    #466696
    i would check control board for blown caps as a long shot
