SMEG Cucina 375 oven safety thermostat
Home Forums Public Support Forums Spare Parts Help SMEG Cucina 375 oven safety thermostat
  • #94085
    pointsman
    Good afternoon,
    I am pointsman and have recently joined this forum.
    I recently ordered an oven safety thermostat from UK Whitegoods for my SMEG375 Cucina oven. From the picking list, it is listed as having a cut off temperature of 190 deg C for this model. Upon removing the old stat, I noticed that this is rated at 100 deg C.
    The main oven stat is fine and keeps the temperature (within about 10-15 deg C) checked with a Fluke temp probe at various settings.
    Can anyone confirm if this higher temperature safety stat is correct? It seems that 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} over the original temperature is excessive, bearing in mind that the oven has been working fine for the last 10 years without a problem until recently when it has been temperature tripping.
    Any help would be welcome.
    Thanks,
    pointsman
    #456405
    Re: SMEG Cucina 375 oven safety thermostat
    Can you give us the full model number please as that’s not valid or only partial as there are multiple models with 375 in them? There will be some letters before and after I’d imagine.
    pointsman
    Hello kwat,
    Thanks for replying to my post.
    The full model number is SE375MFX5 CUCINA EFFECT MF OVEN
    Date of manufacture 11.01.06
    pointsman
    #456407
    The safety stat, 41827 on the attached is this one:
    https://shop.ukwhitegoods.co.uk/8187303 … thermostat
    And is a 100?C stat.
    pointsman
    Hello kwat,
    Thanks for your prompt and helpful reply. I will order the correct stat to complete the repair!
    Once again thanks very much.
    pointsman
