smeg d 612shwasher fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum smeg d 612shwasher fault
  • #71909
    antman08
    🙁 can anyone one help me with a fault on a smeg dishwsher model DI612…..when switch on the machine will programme ok..door shut ..it pumps out normally then it fills and pumps at same time for about 1 to 2 secounds..stops..beep from circuit board..then does the same again…fills and pumps again for 1 to 2 secs…stops ..beep from circuit board..then does it all over again…and again and again…no fault code though..float switch doesnt appaear to be lifting…and when i did lift it manually..goes into fault mode as it should..can anyone help..is it pcb board…heeeelllp…
    #382769
    Re: smeg d 612shwasher fault
    Are you sure there’s no error code?
    If not then it is possible the board is faulty, it sounds as if it is registering an overflow but if the float switch is okay then it shouldn’t do so.
