This m/c will start the programme then after a couple of minutes error code E9 appears (water in base according to book) but still does it with the base off – no sign of any water anywhere in base!
Repetative overfill. Can be p/sw; more likely pcb not turning off valve. Had one recently with blown suppressor, changed it and it all worked. Also had several where it was the pcb itself.
