Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › SMEG D/W MODEL DF614BE
- This topic has 13 replies, 5 voices, and was last updated 17 years, 2 months ago by
funkyboogy.
February 2, 2009 at 5:41 pm #43098
funkyboogy
Participantwhen filling makes a chattering noise like solonoid valve chattering
continues to fill ok , wash pump kicks in washes for 2-3 mins then it cuts out
led with 2plates symbols flashing and led with pans lit up.noise isnt from drain pump ..wash pump been striped down as well to check for foreign objects
appliance has had new dispensor recently, noise isnt coming from disp
any ideas
allyFebruary 3, 2009 at 7:29 am #276056funkyboogy
ParticipantRe: SMEG D/W MODEL DF614BE
this appliance has 5 leds..
its the 4th from left thats flashing and fifth is lit..
allyFebruary 3, 2009 at 10:54 pm #276057eastlmark
ModeratorRe: SMEG D/W MODEL DF614BE
Guess you really need to find out where the chattering is coming from and go from there, could be a duff pcb. Just wire another coil on that dispenser just to make sure. The fist dispenser coil may have done the module in.
February 4, 2009 at 7:38 pm #276058funkyboogy
dont suppose any-one has fault codes for this d/w..
it has 5 leds 4th from left flashing an fifth staying lit..had a look at parts dia today and seen water diverter valve…could this be making the noise..
noise is coming from base of appliance
cheers allyps this is a free standing d/w and leds are on front control panel
February 4, 2009 at 7:43 pm #276059eastlmark
all smeg error codes are essentially the same and that is not any of them. Unlikley to be the diverter valve as that would give you an E8. Its a stepper motor and a microswitch so it should be easy enough to ID if the noise is coming from it. IME its only ever the dispenser that makes that chattering noise. The only other source could be the regen valve on the water softner, just take the sides off and run it, it shouldnt be too hard to work out where its coming from.
February 4, 2009 at 8:10 pm #276060funkyboogy
CHEERS did have the sides off still couldnt make mind up it seemed to be coming from middle area in base..
very strange noise…it sounds like valve chattering may not be a valve ?
sure if someone had fault code i might be able to work prob out..
allyFebruary 4, 2009 at 9:45 pm #276061eastlmark
OI its not a fault code, OK!
It could be a jammed alt valve as that is dead centre.
February 4, 2009 at 10:11 pm #276062Dansta
Its the salt regen solenoid,had it a few times,dan
February 4, 2009 at 10:16 pm #276063Dansta
not had it cause the cycle to stop though,might be overfilling aswell,check the plug on the pressure switch(front rhs)the sometimes burn out.
February 5, 2009 at 8:27 am #276064funkyboogy
cheers guys..bit of a head scratcher,
would the salt regen valve be activated at the start of a prog ??..just to recap …
appliance starts as norm..ie fills >drains for 2 mins..then starts to fill (this is when chattering noise starts)>>complete fill wash motor kicks in (noise still in background) >>cycles for about 2 mins then bleeps/stops..
you can then re-select any progs and it will do the same again.
allyFebruary 5, 2009 at 9:46 am #276065DentedPorsche
Hiya,
Smeg Service site error codes show this error code for some models. E8 diverter valve.http://rapidshare.com/files/194162762/s … s.pdf.html
HTH
Brian 😀February 5, 2009 at 9:19 pm #276066funkyboogy
cheers brian.
will order diverter valve, dont know if i should also take pcb ?
customer a bit of a pain..insurance jobby..she very busy and works ,has kidz bla bla bla bla bla..tried not to yawn to much whilst she was spouting out all her me me me routine.
does diverter come easy ?. looks like a solid base that wont come off.
cheers ally
February 6, 2009 at 12:13 am #276067Penguin45
Centre panel unclips for access.
February 19, 2009 at 8:46 am #276068funkyboogy
update on this job…went back with diverter valve…and guess whatt
it cured the prob…
so if you get a smeg making a chattering noise whilst filling its likley to be diverter valve
ally
