smeg d/washer
  • #77804
    dopper
    its a di612 put it on any programe it drains then goes to fill put fils and pump on and off the programe light flashes 2 times and bleeps does this on any programe, is that an e2 code ?
    dop
    #403456
    Re: smeg d/washer
    owners manual with fault codes
    http://www.smeguk.com/smeg_com/docs/man … 206-EN.pdf
    dopper
    Re: smeg d/washer
    cheers for that but didnt help as no normal code coming up, just what i said its the programe light its on that flashes no other lights
    dop
    #403458
    Re: smeg d/washer
    dont know this models timer very well but i would look at pcb to see what sort of power supply it uses. the early ones used a 1.5uF cap which is prone to failure and acts like a low battery fault. ie turn one thing on ok turn on two and timer crashes (see stick above on pcb repairs )
    also early models use to throw up fault when the soap draw solenoid was faulty dont know if this fault still causes probs on the later one
    finally look for earth leaks causing all sorts of probs on machines these days
    dopper
    Re: smeg d/washer
    cheers will do
