smeg d/washer code
  • #33470
    dopper
    got a customer rang says e8 code on d/washer. checked code it says read error rest and try again anyone know what that means?
    cheers paul
    #238842
    Re: smeg d/washer code
    dopper wrote: it says read error rest and try again
    The machine can sense when you are tired 😆
    Hopefully P45 will pick up on this one later.
    Alternator valve failure. Can be spurious error if part not fitted. No model, so no idea.
    dopper
    its a dw1614 it will sometimes work once then this code comes on again
    #238845
    dopper
    update on this one ,took to workshop, worked on every programme?
    #238846
    Change the alternating valve, they are troublesome anyway and its bound to be the cause. 819130468
