Re: smeg d/washer code
It means the flow meter is duff……..only problem being it doesnt have one!
Its a software glitch easily solved.
With the door open, turn on the appliance and within three seconds push 4 times on the program selection
button – The test program has been selected if the SOAK and STRONG LED’s are flashing
This LED combination represents the test program for the appliances that have a flow meter.
If the above indication is not shown on the appliance, switch the appliance off and try the sequence again
until the above LED’s are shown on display.
Now push on the program button once more to select the version ‘without flow meter’, check that the SOAK
LED goes out, and the display is indicated as below.
Do not close the appliance door, to complete settings switch the appliance off.
Now switch the appliance ‘on’ and test on a SOAK program.
It is possible for this fault to exist on earlier models, if the appliance has had a PCB replaced with the latest
version. (earlier model are ADP8112 & 8132).
ps have emailed you the full coulur version.
